Error - PowerSDR 2.8.0.151
VE5KC
Post by VE5KC »
Hi Darrin..
First, TNX for all the great work you are doing on PowerSDR!
I'm running a Flex 1500 with 100w amp. I sold my flex 6400 and like this setup with PowerSDR much better.
My computer system: OS Windows 10 Pro - latest version and updates.
CPU i5 8400 with 16GB RAM
Here is the info on an error I am getting with PowerSDR 2.8.0.151.
The following error occurs when working with adding and changing entries in the Memory Interface window.
With this error you are given the following options:
click Continue - the program keeps going
click Quit - PowerSDR closes immediately
73.. Ken - VE5KC
The following is the error info from windows
Memory Interface
Unhanded exception has has occurred. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Index was out of range. must be non-negative and less then the size of the collection.
Parameter name index.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.Collections.ArrayList.get_Item(Int32 index)
at System.Windows.Forms.DataGridViewRowCollection.SharedRow(Int32 rowIndex)
at System.Windows.Forms.DataGridViewRowCollection.get_Item(Int32 index)
at System.Windows.Forms.DataGridView.get_Item(String columnName, Int32 rowIndex)
at PowerSDR.MemoryForm.ScheduleUpdate()
at PowerSDR.MemoryForm.dataGridView1_CellMouseDown(Object sender, DataGridViewCellMouseEventArgs e)
at System.Windows.Forms.DataGridView.OnCellMouseDown(DataGridViewCellMouseEventArgs e)
at System.Windows.Forms.DataGridView.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.DataGridView.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4150.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
PowerSDR
Assembly Version: 2.8.0.151
Win32 Version: 2.8.0.151
CodeBase: file:///C:/Ham/PowerSDR%20-%20Flex%201500/PowerSDR%20v2.8.0/PowerSDR.exe
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.8.4001.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
Win32 Version: 4.8.4121.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PowerMate
Assembly Version: 1.0.7053.28506
Win32 Version:
CodeBase: file:///C:/Ham/PowerSDR%20-%20Flex%201500/PowerSDR%20v2.8.0/PowerMate.DLL
System.Speech
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Flex1500USB
Assembly Version: 2.0.18.0
Win32 Version: 2.0.18.0
CodeBase: file:///C:/Ham/PowerSDR%20-%20Flex%201500/PowerSDR%20v2.8.0/Flex1500USB.DLL
wdapi_dotnet1040
Assembly Version: 10.4.0.0
Win32 Version:
CodeBase: file:///C:/Ham/PowerSDR%20-%20Flex%201500/PowerSDR%20v2.8.0/wdapi_dotnet1040.DLL
msvcm90
Assembly Version: 9.0.30729.9619
Win32 Version: 9.00.30729.9619
CodeBase: file:///C:/WINDOWS/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9619_none_508d9c7abcbd32b6/msvcm90.dll
Sanford.Multimedia.Midi
Assembly Version: 5.0.0.0
Win32 Version: 5.0.0.0
CodeBase: file:///C:/Ham/PowerSDR%20-%20Flex%201500/PowerSDR%20v2.8.0/Sanford.Multimedia.Midi.DLL
Sanford.Multimedia
Assembly Version: 6.0.0.0
Win32 Version: 6.0.0.0
CodeBase: file:///C:/Ham/PowerSDR%20-%20Flex%201500/PowerSDR%20v2.8.0/Sanford.Multimedia.DLL
Interop.TDxInput
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Ham/PowerSDR%20-%20Flex%201500/PowerSDR%20v2.8.0/Interop.TDxInput.DLL
FlexCW
Assembly Version: 1.0.2.0
Win32 Version: 1.0.2.0
CodeBase: file:///C:/Ham/PowerSDR%20-%20Flex%201500/PowerSDR%20v2.8.0/FlexCW.DLL
FlexControl
Assembly Version: 2.0.0.0
Win32 Version: 2.0.0.0
CodeBase: file:///C:/Ham/PowerSDR%20-%20Flex%201500/PowerSDR%20v2.8.0/FlexControl.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
atu
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Ham/PowerSDR%20-%20Flex%201500/PowerSDR%20v2.8.0/atu.DLL
Microsoft.GeneratedCode
TNF
Assembly Version: 1.0.0.2
Win32 Version: 1.0.0.2
CodeBase: file:///C:/Ham/PowerSDR%20-%20Flex%201500/PowerSDR%20v2.8.0/TNF.DLL
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
AutoItX3.Assembly
Assembly Version: 3.0.0.0
Win32 Version: 3.3.14.5
CodeBase: file:///C:/Ham/PowerSDR%20-%20Flex%201500/PowerSDR%20v2.8.0/AutoItX3.Assembly.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Re: Error - PowerSDR 2.8.0.151
Ken,
If the Memory.xml is corrupted, the only choice is to either open the file and see if you can locate the issue, or remove it and allow PowerSDR to start over. Right click on the TX waterID callsign box (top of the console). This is your database folder. navigate back 1 level to the FlexRadio Systems folder and you will see the memory.xml file.
Then when you add the memories you want, make a manual copy of the file (just in case)
VE5KC
Post by VE5KC »
Thanks Darrin,
Seems to be solved ..
I upgraded to PowerSDR 2.8.0.153 and no longer have the error.
73.. Ken - VE5KC
