Solved: Flex 3000: Vox is not working
HB9DDS
Post by HB9DDS »
PowerSDR 2.8.0.250
Flex-3000
Vox is NOT working. Normal Mikrofon (Yaesu) is perfect, but Vox is not switching in any way.
Daniel
HB9DDS
Re: Flex 3000: Vox is not working
First make sure VAC1 and VAC2 are both OFF
Change Meter #2 (tx meter 2nd) to Combo
You should be able to see the Mic audio level as you talk, while in Received mode.
If you cannot see a mic level (but your mic does work when you manually transmit), then reboot your PC and Cycle power to the radio
If you still cannot see the mic audio during receive you may need to either import a backup database file or do a factory default and start fresh.
HB9DDS
Post by HB9DDS »
Hi Darrin
This was it! Tnx
Daniel
HB9DDS
