Is there a step missing from the setup for remote with teamviewer? 2 of us are having trouble setting it up, It works fine for the digital modes where you do not need any audio to be passed either way but there is no audio from the radio PC to the remote PC.
Scott
N2SAB
Remote with Teamviewer
Re: Remote with Teamviewer
Scott,
As far as I can tell 2-way audio no longer works properly with Teamviewer.
When you activate the MIC (on the remote side) any noise on the MIC stream causes the Received audio (on the remote side) to MUTE instantly. There is no way to turn off this silly MUTE, and there is no longer a way to manually set the threshold for the MUTE (there used to be a slider to adjust).
Microsoft Remote desktop 2-way full duplex audio works great, but has 2 issues: They never fixed the issue where the video and audio get out of sync, and it requires you to open up a PORT through your router (and they recently discovered a security issue). Hopefully because of the security issue, maybe they will fix both issues?
I finally solved the teamviewer issue. I now have it working remotely in full 2-way operation.
I posted the screen shots on my webpage. Load my webpage and refresh it. Then go to the Remote Desktop link and you will see the new screen shots.
Thanks for the info, we will look at it and give it a try.
Scott
N2SAB
Scott
N2SAB
