Recurrent activations of DttSP Autostart Topic is solved
Until recently I have never noticed the DttSP activations. I am running Windows 10 pro, Flex 5000, Powersdr 152. I have completely unloaded and reloaded several previous versions of Powersdr and continue to see these activations even with 3D off, High Res panafall off. I have never been able to get it to work with 192000 Sample rate with out it freezing up and had to reload it and run at 96000. Are these issues related?
Re: Recurrent activations of DttSP Autostart
"DPC latency" is the cause of the DttSP lockup.
If you cannot run your 5000 at 192k, its either the PC is struggling with the load caused by the FireWire data, or the FireWire card, or FireWire Driver.
If I ever see a lockup occur, I always open the windows Task manager and see what is running in the background.
But if you have at least 4 cores on your PC, I would lean towards getting a different FireWire 1394 card.
How many cores/threads does your PC have, and what type of FireWire card? Does it have a 1394A and B port or just the 1394A port. I would make sure you have a card with both 1394A and B. The B means the card is more an capable or the speeds needed for PowerSDR. I dont trust the older cards.
Thanks for the reply. I am running a Intel i78700K cpu @ 3.70Ghz, so horsepower should not be a concern. I am running a Via 1394. I am not sure of "A" or B" Driver info below
- InstallDeviceID
DriverName 1394.inf_amd64_2336da6415b7dc6f
DriverVersion 10.0.18362.1
DriverProvider Microsoft
DeviceInstanceID PCI\VEN_1106&DEV_3403&SUBSYS_34031106&REV_01\4&2EBC2115&0&00E5
SetupClass {6bdd1fc1-810f-11d0-bec7-08002be2092f}
RebootOption false
UpgradeDevice true
IsDriverOEM false
InstallStatus 0x0
DriverDescription VIA 1394 OHCI Compliant Host Controller
Do you recommend any specific card? Can the 800M slot be used? I am currently using the 400M slot. It appears they sell a 9 pin to 6 pin adapter cable, is this an option?
Thanks for your help, I love what you are doing with Powersdr
KD9GYT
Marty
- InstallDeviceID
RebootOption false
UpgradeDevice true
IsDriverOEM false
InstallStatus 0x0
KD9GYT
Marty
1394B is the smaller 800mb port. it just signifies a newer chip design.
I was using a VIA chip firewire previously, but It was acting strange (if you tried to change drivers it would crash my PC), so I bought a new board from Ebay using a TI chip "XIO2213B" and have no troubles at all.
Your cpu is similar to my Ryzen PC, (6core/12thread).
I have more info on my webpage. Click the Firewire link on my webpage.
I went out and replaced the firewire card with a new Syba 3-port FireWire Combo PCIe Controller Card and cable and doubled my computer ram to 32 Gigs.
What difference! I can now run it at 192K, first time ever
Darrin Keep up the great work and thanks for the help
Marty
KD9GYT
Marty
KD9GYT
Re: Recurrent activations of DttSP Autostart Topic is solved
Great. Thats what I would expect!
Syba is the card I am using (with the TI chipset).
The VIA chips worked well until Win10, but apparently are now too old.
I normally have FireFox, Visual Studio, Dreamweaver, WSJT-X, HRD, and PowerSDR all running at the same time with no issues.
Also running a Crucial solid-state drive makes a big difference.
